Static caravan hook up | Page 2 | on ElectriciansForums
Discuss Static caravan hook up in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'd be absolutely fine wandering about re-setting a couple of RCDs (should be an rcbo now shouldn't it?) in the dark in me wellies and know that there's no safety issues (apart from the sodding holes in the hookup either side of the RCD and MCB).
I have owned 5 houses during my 21 years of marriage and I have had to reset an RCD maybe 5 times. So, assuming once every 4 years....
Now, in my neck of the woods we get a power cut about 5 times a year, often for several hours....
Conclusion - RCD's do not inconvenience me, but overhead lines do :)
Reply to Static caravan hook up in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening all, Just after a sense-check before I commit & send the quote. I’ve been asked to run in an SWA to feed a small CU that’ll sit inside...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
