Morning all
Bit of advice needed on a very large modern static caravan/mobile home a customer has bought to be sited on his land (Farm) that he intends to move his son into.
The supply will come from a modern TPN Wylex board, it will have its own TT installation, the caravan is all
electric including the central heating system. The main board in the van is protected by a 63A 30mA RCD.
I intend to run the supply in 16mm SWA XPLE it will be clipped direct through large barn with the final 3 meters being buried. Total run is 55 meters.
Main question is what to use to protect the cable at the main board does it need to be RCD/RCBO or will a standard type B MCB suffice? If using RCD/RCBO would it need to be 100mA?
