Static | on ElectriciansForums
Discuss Static in the Australia area at ElectriciansForums.net
test from sink to MET on low ohms. if you get a very low reading, then it probably is static. tingle due to body having as static charge and discharging to earth on touching the sink. what is the floor material? sometimes spraying the flooring can eliminate the problem esp if carpet with a hiugh nylon content.
i don't know what it's called, it's an anti static spray. there are firms specializing in it. years ago, the firm i worked for installed an alarm system in a new office. every time the girls put the key in the panel, they got a static shock. we called in this firm and rthey sprayed the carpets. end of problem.
Reply to Static in the Australia area at ElectriciansForums.net
T
PRV with Gauge Question Hi, I have a Caffeli PRV near the mains stopcock. Static pressure fluctuates between 3-4 Bar and when a tap is opened it...
techweb
T
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
