Steel conduit in tight spaces | Page 2 | on ElectriciansForums
Discuss Steel conduit in tight spaces in the UK Electrical Forum area at ElectriciansForums.net
London
I need to run a length of steel conduit. One end it will connect into a standard 25mm BESA box, on the other end, it will go into a sharp elbow. The conduit has to thread through a hole in the floor that is very close to the wall. If I thread the conduit through the hole and then place either the BESA box or the elbow on, it stops me from being able to turn the remainder 360 to screw in the other end.
Is there a trick I don't know about when in situations like this?
Usually cut down to the size you need, useful when you need a short piece between female sockets that are too short to thread. Must be painted like all exposed threads.
Edit: I was well slow.
One more question for you guys.
When joining conduit to an external waterproof socket is it okay to use standard couplers or should I really use flanged couplers? I'm just thinking about ensuring the best waterproof seal possible. I see some flanged couplers come with rubber washers and some with lead.
Normally flanged couplers shouldn't have rubber washers as that will hinder the earth continuity.
If you mean joining a steel conduit to a plastic external socket then I guess replacing the soft metal seal of a flanged coupler with a rubber one is the best plan.
Barton Conduit list 2 flanged couplers, one supplied with a lead washer, the other with a neoprene washer. I've only ever seen the ones with a lead washer though.
Good points re earth continuity. In my case, I'm attaching to plastic outdoor sockets. still, very hard to come by flanged couplers with rubber washers.
I do also find it weird how you can't find rubber gaskets for tees or inspection elbows. You'd think they are equally prone to water ingress as a BESA box, for which gaskets are easily available.
Get some box gaskets and cut them to suit.
Good scissors and a bit of practice.
I always use box tees and angles anyway with natural bending, very occasionally elbows, due to lack of room.
Unfortunately electrical installation components are available in only a limited range of styles and sizes, many less common items are very difficult to get hold of. If you go to America you can get anything you want from the local DIY store. Most of the items in that link look far superior to the junk we have available here.
Wow! I can't understand why we don't have the same range available in Europe/UK. Some very handy bits there.
Which bits do you think would be useful in the UK?
I can't see much there that either there isn't an equivalent available here or is of much use here.
There are some fittings which used to be common in the UK but don't seem to be widely available any more, if at all. I often want tangent boxes for surface work.
I don't think I have seen an offset nipple (at least in conduit).
Is this the sort of tangent box you mean?
Reply to Steel conduit in tight spaces in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
