Stereo speakers rocker switch | Page 2 | on ElectriciansForums
Discuss Stereo speakers rocker switch in the UK Electrical Forum area at ElectriciansForums.net
Thompson
Alberta
At our cottage, we have a stereo in the living room, on the deck and out by the covered firepit. Way too many stereos, cables, remotes, etc. What I want to do is have one stereo (living room), a rocker switch panel, and then wires out to speakers to all these locations. I feel I need rocker switches with 4 pins, but can only find 3 pins. Rocker switched with 4 pins would be for the stereo wires (pos/neg) going into the switch, then stereo wires (pos/neg) going out to speakers.
So, I guess my question is, am I doing this correctly? Is there an easier way?
Thanks for any help.
Cheers
It's tetrode output, with a separate rectifier and HT rail for the screens, fixed bias nearly -80V and a 6SN7 as cathode-follower driver. The grid current is pretty horrendous at full welly.
I should fish it out and fix it. I have 197 other projects and 0 time, but it would be fun. I'm also about to move my bench into a different room and it will come to light in the process.
OP, sorry, drifting a bit here!
[automerge]1593204387[/automerge]
Ha, found a pic of the PSU before I took it apart, sans lampes. They would be an 83 mercury vapour rec for the main HT (note ceramic UX4 socket), a 5U4 for the G2 / driver supply and a 6X5 for the bias. Main HT transformer came from a WW2 submarine.
The 7-pin O-Z socket connects to the amplifier, with 550V, 350V and whatnot accessible on those uninsulated contacts. I didn't then know that there was supposed to be another paxolin insulator that's missing from this socket. It didn't worry me at the time because I was going to include a pilot circuit with a relay that only grounded the HT secy CT once the neg bias was proven at the far chassis. but that bit never got finished. I got worried about the ground pin going O/C sending the amp chassis up to HT, and doubled up with what was going to be the pilot pin.
  • [ElectriciansForums.net] Stereo speakers rocker switch
Reply to Stereo speakers rocker switch in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
