Still fitting plastic ?? | Page 2 | on ElectriciansForums
Discuss Still fitting plastic ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And I was thinking preclude meant;
prevent, make it impossible for, make it impracticable for, rule out, put a stop to, stop, prohibit, debar, interdict, block, bar, hinder, impede, inhibit,exclude, disqualify, forbid; estop
:innocent::dunce:
Yes it does, so you could rewrite the note with the word preclude substituted with prevent
NOTE 2: The implementation date for this regulation is the 1st January 2016, but does not prevent compliance with the regulation prior to that date.
Reply to Still fitting plastic ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
