Guest viewing limit reached
I wish, without putting myself in even more of a hot pot there's a 100k project built around all of this rubbish...led lighting and pv are well within my safe zone but this is a curve ball and one that it seems to all hinge on
And of course the release of heat is controlled mechanically not electrically so whatever you do to the wiring won't help!
Agree with this post, I can only think that someone has got confused between storage and instantaneous systems because it makes no sense otherwise !! Unless some numbnut thinks they store electricity and not heat ?
Am I thinking logically at all or barking up the wrong tree? Any other suggestions or options?
Any help or ideas appreciated.
Tony
I think you're barking up the wrong tree.
As others have said, you can only use a PIR for instantaneous heaters. Think about how the storage heater works... If nobody is in the office on a Sunday, the PIR won't trigger so they won't heat up for Monday.
You can get storage heater controls such as weather watchers and you could install a time clock / contactors to only charge the storage heaters 5 days a week.
Other than that, there's not much more you can do.
Sorry all when referring to switching the neutral I'm referring to the internal wiring of the unit and not the supply. I've attached a screen grab of the internal wiring which vent axia say would be the only way of doing it.
You still don't switch the damned neutral, that's why the room and limit stats are in the live!
And all of that wiring is the off peak supply, which will only be live when the building is unoccupied and therefore the PIR will only switch on for its 5minutes startup sequence if it has one.
Isolating the heaters permanently will have the same effect and cost a lot less to do!
Think it can be done, all you have to do is have someone in room at night to make heaters work, if more than one room they will have to walk from one room to the next, then all heaters will heat up and then do wot they do as in let the storage heat out in the day to heat the room
Sorry for spelling mistake but had too much to drink and think this is a p''s take
We did controls for storage heaters for some Highland Regional Council buildings, they definitely had some active way of controlling heat output during occupancy but it's a long time ago so can't remember if this was via dampers or fans. They also had direct heating elements that would top up if the stored heat was exhausted. Your customer/consultant may have assumed that yours are similar. HRC did a lot of tuning of their storage heating systems, essentially trying to use the minimum charge they could get away with, since their tariff for direct heat was the same. This was back in the 80's before the bottom fell out of the energy saving market.
maybe some sort of control that opens and closes the heat release flap?
has there been some confusion over the type of heating, perhaps you should confirm that you are talking about the same heaters as they are.
Firstly, thanks to all for making sense after a long day, the Green deal idiots thought that the storage heaters had boost options for daytime running and hence the occupancy sensor requirements. for my balls up of bleating on about switch neutrals, ill put that down to my good friend Stella.
Thanks for talking sense all :biggrin:
I think the occupancy control operates a secondary convector fan in each unit to circulate hot air when needed. It certainly makes no sense to control the heating elements to the storage bricks as they need to be hot, which takes time.
Storage heaters
Thread Tags
a1colly,
ackbarthestar,
