P
prb1
Hi all,
(I am not an electrician)
Problem.
I have night storage heaters (x5). I want something to help control the charge centrally so that I can look ahead a few days (or more) and set the overnight charge length to suite the weather during the next few days. I get fed up changing the "input" of every heater (or even turning off) every night. I dont mind about the hot water charge as I could do that manually if nec. on day tariff. (it lasts a couple of days anyway). I guess what I'm thinking of is a programmer wired to a relay on the feed between the main meter and economy tariff meter which would be programmed to either off or a to run a specified length say between 3am and 7am etc. This way I could look at the weather for the next week and in 3 minutes set the heating for the week ahead (the charge being proportionate to the "on" time). Is there anything out there that a qualified electrician could install? and what sort of price might it be? Any help appreciated.
Problem.
