potentially dangerous as when both switches are with common switched to L, the light is off, so Mr. layman would think it was safe to stick his sausage fingers in there.
Discuss Strange 2-way wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
My thought is the intention of the reg is the N not be disconnected unless its coordinated with the L being disconnected, as per DP switching. Whereas the drawing allows N to be disconnected when L is continuous.Hmm, sounds like a grey area to me. By the letter of that reg as it's written the switching arrangement in the OP would be fine. If the reg said 'operate' instead of 'inserted' then it would apply but both live and neutral are 'inserted' so it could be argued it doesn't apply.
Yes I'm sure, why do you ask?Are you sure it's a neutral at the switches and not just red and black used as strappers?
Reply to Strange 2-way wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
