Strange fault | on ElectriciansForums
Discuss Strange fault in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hi All,
I was called out yesterday to a customer that has been having trouble with the electric tripping on various circuits (16th edition mem2000 board)
When I got there I had a quick look and couldn't find anything obvious anyway cut a long story short did a full eicr, all circuits good.
She's phoned the dno no reported problems in the area.
Ive explained it's probably something they're using as it never trips when they're out, or maybe could be a water leak after a shower etc, but still no pattern.
I've isolated the outside lights and it still occurred last night.
The strange bit though is its the non rcd side and she's claiming the main switch tripped along with some mcb's.
I thought perhaps a faulty switch so replaced with one I had in the van but as I said it happened again ! Is this possible as I've never come across a switch that switches itself off and no its definatley not an rcd. It's 1990's house and doesn't appear to have been messed around with too much.
Confused please help!!
:rolleyes4:
definitely a weird one. since you said various circuits, it's obviously not something stupid like an overload in the kitchen or something. odd about the main switch too. let us know if you do figure it out!
No all the house sockets are on the rcd side and even with everything on (sockets, oven, hob and all the lights.)it was pulling less than 40amps on the clamp meter.
Seems to be both light circuits tripping with the main switch?
both light circuits tripping. you mentioned you isolated the outside lights..
guessing they are on one or both of the circuits tripping? also, how many outside lights are there? any chance they are overloading? long shot I know.
Reply to Strange fault in the UK Electrical Forum area at ElectriciansForums.net
I misread it.
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
