Strange fault | Page 3 | on ElectriciansForums
Discuss Strange fault in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hi All,
I was called out yesterday to a customer that has been having trouble with the electric tripping on various circuits (16th edition mem2000 board)
When I got there I had a quick look and couldn't find anything obvious anyway cut a long story short did a full eicr, all circuits good.
She's phoned the dno no reported problems in the area.
Ive explained it's probably something they're using as it never trips when they're out, or maybe could be a water leak after a shower etc, but still no pattern.
I've isolated the outside lights and it still occurred last night.
The strange bit though is its the non rcd side and she's claiming the main switch tripped along with some mcb's.
I thought perhaps a faulty switch so replaced with one I had in the van but as I said it happened again ! Is this possible as I've never come across a switch that switches itself off and no its definatley not an rcd. It's 1990's house and doesn't appear to have been messed around with too much.
Confused please help!!
:rolleyes4:
Has she got a isolator between meter and board. If so she still has a means of isolation, along with mcbs (although not dp). Then do as suggested lock out mains on board (in on position). Then see what happens.
Hi all sorry for not replying last night it was my boys birthday so I was out,.
It tripped again twice last night and these were the photo's she sent me.
On the first time everything is off except the rcd ! and the second just the main switch.
I reckon it could be the daughter as she was near the downstairs toilet (where the cu is) both times, customers not having it mind!
Please tell me it's not me being thick this is impossible isn't it.
Also I never mentioned when I did the eicr I tried to find out which circuit it was I swapped one at a time all the circuits onto the rcd side and they all functioned normally for me.
Thanks for all your replies.
[ElectriciansForums.net] Strange fault[ElectriciansForums.net] Strange fault
Maybe someone thinks that green means "go".
There is no way I can think of that all the MCB's, plus the main switch would end up in the off position unless..
a) Someone is messing
b) There is a ghost
You have done all that you possibly can, so maybe suggest to the homeowner that they get someone else to come and have a look at it.
I know you won't want to walk away from the problem, but I really can't see how it is anything other than human interferance.
I know mate it feels fine when closing, def think someones messing around.
I would disconnect the main switch inside the consumer(without telling them) and just have the rcd covering the board....I'm guessing there's another isolator on the tails?
If it opens again then someone is extracting the proverbial mate lol
edit
and put another mcb in, but not wired up, and see if that trips lol
Reply to Strange fault in the UK Electrical Forum area at ElectriciansForums.net
I misread it.
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
