Strange MCB Tripping | on ElectriciansForums
Discuss Strange MCB Tripping in the UK Electrical Forum area at ElectriciansForums.net
N
newsparky
Afternoon all,
Got called out to look at some external lights in a block of flats as management company said they were not working.
They are operated by a C10 MCB and wired via a photocell.
When I reset the MCB and cover the photocell the lights are all fine.
After speaking to a couple of tenants they said the lights just switch off over night.
First assumed it may have been rain as 2 lights were smashed so replaced them.
IR tests are all fine so am a bit stumped as to why they randomly trip the MCB over night?
All suggestions would be much appreciated.
Could be a faulty MCB. Might be worth visually inspecting all the lights also. Remember rule number 1 though :
Always ignore what the client says and work it out for yourself.
Are you saying the MCB controlling these light fittings has tripped again since you have replaced the fittings?? If so have you tested anything at all before coming here asking for advice, if so what tests have you performed, and what values did you obtain??
All lights were inspected and fine apart from the ones I replaced.
I agree with possible MCB fault but seems strange why it only happens when I'm not on site!
What results did you get when you IR tested the circuit?
What results did you get when you IR tested the circuit after it had been on long enough to get up to working temperature?
Was there a difference between the two results?
Reply to Strange MCB Tripping in the UK Electrical Forum area at ElectriciansForums.net
This is a baffling fault I've been fighting with for a couple of weeks now, so I wondered if another set of eyes will help. I installed an EV...
