Siracusa
I have a 20 amp gfci pool pump breaker that trips only when the pump is off during the night. Pool pump runs fine all day. I turn pump off manually at night by using the manual switch on a Intermatic pool timer. Watch it for 5 minutes and note that breaker remains in on position. Go out in morning and breaker is tripped. Breaker is in a protected box with no water intrusion, no rain on these days etc. The only item on the circuit is the 220 pump.
Pool timer pins have been removed temporarily so we dont worry about timer clicking on.
Since timer is after the breaker and is set to off, doesnt seem the timer or the pump itself should have anything to do with the tripping.
Any ideas? Many thanks
