Strange RCD Fault | Page 12 | on ElectriciansForums
Discuss Strange RCD Fault in the UK Electrical Forum area at ElectriciansForums.net
G
Guest569
80amp main switch RCD, occasionally trips when a couple of circuits are switched on (doesn't matter which circuits) with nothing plugged in.
IR tests all good. Replaced RCD for new. Happens in all weather ( don't think its external )
Only sockets on this consumer unit.
Ive had my guys out at it twice with no joy. New build wiring from 16th edition.
Im going to investigate myself this week, Im sure Ive had loose connections causing tripping before, it about all I can think of, a loose tail somewhere around the main switch.
Anything else to look out for ?
Im pretty certain its not a dodgy nail at floorboard etc its fairly new property and in good condition with chipboard throughout.
Just to stick my 10pence worth in, have you checked the actual socket fronts for faults, as you said all ok until you connected last socket.
for dead test purposes only, remove the socket fronts of the offending circuit Try connecting cables together with connectors and do your tests before putting socket fronts back on.
It could be something as simple as a faulty fitting.
Sounds like the house holder may have to re-mortgage to get this ring main fault sorted out, Wet leaf my ---
well he might need a fig leaf to hide behind when it comes to `customer relations`...lol..
to the OP:
forget about wet leaves...how about an olive branch...held out to this most patient of customers for all the arsin about that has gone on (including looking like an amature outfit by sending `the boys` round who clearly dont know one end of a tester from another)...this could take the form of not charging for all the time you have spent trampling about in their home...disrupting their lives...
caus the only way you can pacify people is with money mate....thats the way the world works i`m afraid..
try it...it would be good `customer relations`...
Back Monday again I believe Glenn LMFAO,
JRC has offered a grand to anyone going up there to sort it out because the fault is unique and and not the type we could sort out easily
well..he`ll probably have to verify it first with his PR team...
who will then be able to offer the choice to the client:
as in `its the spark or the RCBOs love...you cant have both...so you can take the money..or open the box`
from PR expert to banker in 30 secs...
There was an offer of ÂŁ350 made, he never took that up so don't start working out what you'll spend the grand on yet Trev lol.
In the words of that fine Irish band Therapy?
Screw that, forget about that, I don't wanna hear about anything like that.
I'm offering a guaranteed fault find but its going to cost. I'm quite happy to say I WILL find this fault.
Reply to Strange RCD Fault in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
I misread it.
