I NEED ULTRA PRECISSION ELECTRIC TEST
TO FINISH PROBLEM !!!
EINSTEIN = IDIOT
QUANTUM = MANY IDIOTS REAPEAT THIS WHAT START ONE IDIOT
WE NEED ADD CONSTANT MOTION TO NEWTON AND WE WILL SOLVE RELATIVITY PROBLEM
CLASSICAL MECHANIC NEED BE MODIF. WE MUST ADD MOTION TO NEWTON's GRAVITATION
INVERSE SQUARE LAW WORKS FOR LIGHT AND FOR GRAVITATION
WE HAVE RIGHT NOW IN BOOKS VERY SIMILAR EQUATIONS !!!
MAROSZ's proposition
we must add info about constant motion to physics old equations
( velocity arrow,direction, volume ,
Motion is abble change Gravitation Forces )
INVERSE SQUARE LAW and motion
we will be able register problem ALSO INSIDE SINGLE ATHOM !!!
(hydrogen ) Story of the image =>
The First Image Ever of a Hydrogen Atom's Orbital Structure
HOW ABOVE PICTURE WAS MADE ? TIME ? LABORATORY DIRECTION RESPECT TO MOTION 30 km/s ..XX km/s ???
GALLILEO NATURAL FALL DAWN LAW + NEW FACT
VERY OLD LAW 400 years old I ADD neW sentense ( more wide LAW )
m -----------Earth
M
Gallileo proved that mass M and m will natural fall down
in one and the same time
Marosz
m------h------Earth-----h------m >>> motion
Motion and Inverse Square Law ( gravitation )
mass m left and right will not fall down at one and the same time
Go on then, what's the ' ULTRA PRECISSION ELECTRIC TEST
TO FINISH PROBLEM !!!' that is needed? Daz
- - - Updated - - -
This fellers either incredibly bright or a complete wind-up. Unfortunately I'm not bright enough to know which. Daz
SORRY FOR MY ENGLISH PLEASE STUDY PROBLEM
Earth.......SUN.......Earth >>> 20 km/s
................P1
SUN started wave 1 in point P1 ( not exist C+ 20 km/s )
after one sec. we have
....20km.... Earth.......SUN.......Earth >>> 20 km/s
................P1
Earth and Sun made 20 km in space ( light is going to Earth )
INVERSE SQUARE LAW
More far from place where signal started = lower intensity of signal
( "lower brightness" )
1R = X , 2R = X/4 , 3R = X/9
X- brightness, R- radius
the same energy portion but different area
IMPORTANT IS POINT P1 position and distance to Earth from POINT P1
ABOVE I SHOWED WHY WE HAVE WINTER AND SUMMER !! 66.^66 angle it is not olny one reason !!!
CLIMATE CHANGE ?
Our Galactica Accelerate
....20km....Earth---------Sun-----------Earth >>> 20 km/s
...............P1
....40km.........Earth---------Sun-----------Earth >>> 40 km/s
...............P1
More faster = more stronger winter and more stronger Summer
So far your quoting basic quantum concepts of light speed both in and out of a vacuum as well as the concept of motion, this is very basic stuff but what im really having trouble with is your attempts to translate your experiment - your English is good but not good enough to give clear meaning to a complex quantum measurement .... we are having trouble understanding what you are trying to ask us because your question is complex but you only using basic English to do this.
its a wind up. if it were true(which it isnt(copy/paste)) do you think he'd come to an electricians forum, where most struggle to supply a shed with power!!
I made in home test iside Air and Water
in home I can make only test
ELECTRIC wire and electron speed it will be very good tool for more precission test
I hope that You have good tool to measure resistance
+__________________10 meter wire ____________________- >>> 30 km/s
after short time please change +/-
-__________________10 meter wire ____________________+ >>> 30 km/s
You will see different resistance
Motion is able change OHMS
reazon is Inertia ( Mass M = electron )
p1..p2...p3...p4..M---> 2m/s
mass M is moving in space ( electron is inside wire and wire is on Earth )
M---> 2 m/s ( 2 m/s I showing only for Example 30 km/s is better )
To speed UP mass M from 2 m/s -----> 4m/s you mast use 6M joules energy
to stop mass M You must use only M*2*2/2 joules = 2M joules energy
Strange relation resistance and Earth Around Sun 30 km/s motion
Electrician Talk Forum
maciejmarosz,
Kamikaze,
