Strange things at callout | Page 2 | on ElectriciansForums
Discuss Strange things at callout in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Lol funny guys on here ok tell me whats going on then?
Yes i done an ir test between l/n,l/e and n/e all of which cam back greater than 299mohm.
I am getting 248v between l/n and l/e.
Do you have continuity figures for the circuit? R1, Rn or R1+Rn?
High resistance joint on the L (or N). Simple application of Ohm's Law. If you're not pulling any current (I imagine your megger has a high input impedance) then the voltage drop over even a largish resistance will be low, and you will measure a high voltage. Whereas anything pulling a reasonable amount of current (with a low resistance), the majority of the voltage will drop across your high resistance joint.
Hence Handyspark's question, I guess... :)
Thanks happysteve i looked for a joint but couldnt see any.
It might be under the floor or in the wall tho so ill prob end up rewiring it.
Or it might be in the service head, meter, isolator if fitted, a loose henley block connection.
I would put the system under some load and check the voltages all the way through the system. That will help point you in the right direction.
Reply to Strange things at callout in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
