View the thread, titled "Strangest thing you've had to write on an EICR." which is posted in Commercial Electrical Advice on Electricians Forums.
*socket fitted upside down (don't know why, no logic to it, just a random socket on upside down!)
australian electrician?
I have an upside down socket. Wall mounted computer monitor, cable to short to reach underneath. Decided to turn the socket round rather than rewire the monitor. Seemed easier and it's only me going near it.
I had an upside down socket in my living room, was done that way I presume because the previous owner changed the faceplates and the cables wouldn't reach the terminals on the new socket unless upside down!
just remembered a church eicr from years ago, right at the front where the chap with the white collar mills about there was a wall light that connected into a 5amp plug at lower level, the plug was in and switched on, no backplate on the plug though.
same job had insufficient earthing for mains water/gas, refused to go under the church floor to run those cables, labourer got that amazing job, them church lot are known for burying secrets below ground.
we also inspected the organ, after clambering all over it lol, probably put it out of tune, big 3 storey type of organ.
Reply to the thread, titled "Strangest thing you've had to write on an EICR." which is posted in Commercial Electrical Advice on Electricians Forums.
