String in SWA cables | on ElectriciansForums
Discuss String in SWA cables in the UK Electrical Forum area at ElectriciansForums.net
Stroppy
Here's a question: What is the purpose of the length of string found in the middle of larger CSA SWA cables? Strain relief when pulling the cable, or something else?
How large are you talking?
There was string in the SWA I've just done but it was only small 5 core 10mm .... I used it to strip the rather stiff sheath from the cores
The bigger the cores get the bigger the hole in the middle gets, unless the cores are triangular.
I'd guess it's more to keep the shape during production than for any benefit afterwards.
all wrong. the string is the drag cord for the little tiny men to pull the conductors in with. they always pull in an extra string so they know the shortest way out from the tunnel.
Talking about SWA cables, ...How many of you use ''breakouts'' when terminating SWA ends in external installations, wet/humid environments, or Switchboards etc?? Not many i'll wager!! lol!!
Reply to String in SWA cables in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Sounds more positive.
