String Voltage | on ElectriciansForums
Discuss String Voltage in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Leicester
Hi just about to install my first solar system. Been a commercial electrician for 29 years but no PV experience. After pushed away from Micro inverters by advice from people on here I decieded on Solaredge.
Have sized my system on the solar edge designer software. Now thats telling me I need a se3500 inverter with p500 optimisers. My panels are Benq 33w and have a VOC of 71v and there are 12 of them so in my eyes string voltage could be approx 852 volts! Now spec on the inverter says max input voltage 500 volts. Will my optimisers reduce the voltage to match the inverter or have I missed something.
Thanks Phil
Some panels are not compatible with solar edge optimisers. Can't remember wether Benqs are or nopt
Reply to String Voltage in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
    • Friendly
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
