Struggling please help | on ElectriciansForums
Discuss Struggling please help in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
daws124
A 230v single phase double wound transformer has an output of 20A at 110v
Determine the
kVA rating....
Primary current...
Transformation ratio...
Please explain my brain is mush! Thank you.
Yeah I understand that completely but I have not come across these words in the reading so far,so it's just thrown me a bit! Is the primary current 41.8A?? Just need a bit of guidance :/
Upvote 0
I saw you're from Harrogate - not at Harrogate College by any chance are you - if so how are you finding it? In my experience I'd advise you to enrol with York College!
One of the guys that qualified the year before I did was teaching 2330 the year after he qualified, it was an absolute disgrace.
We had students teaching the tutors how to terminate MIC and SWA. The college had failed numerous external C&G audits due to the internal mess the department was in, and the inability/lack of skill and experience of the tutors.
I pray that the whole department has had a massive overhaul before the college releases more 'electricians' into the trade!
Upvote 0
I only started the course on Monday so I apologise for my ignorance. I think I have the primary current at 41.8A and the transformation ratio at 2.09:1 it's just the kVA rating I'm lost with,having said that are the other answers correct?? :/
Thanks for the guidance.
Upvote 0
For simplicity's sake, assume it is a 100% efficient transformer, so the Power In = Power Out. (which is its kVA rating)
Use the equations up above to work out the Primary current, I[SUB]P[/SUB] and the kVA rating.
Your turns ratio is correct!
Upvote 0
Reply to Struggling please help in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
Electrical Courses
