Stupid Bloody Lightbulbs! | on ElectriciansForums
Discuss Stupid Bloody Lightbulbs! in the UK Electrical Forum area at ElectriciansForums.net
Sam Bancroft
Hi All,
Quick question which hopefully you'll be able to tell me how stupid i'm being - but how do you change these lightbulbs?! It's not like I've got an engineering degree........ oops.
[ElectriciansForums.net] Stupid Bloody Lightbulbs![ElectriciansForums.net] Stupid Bloody Lightbulbs![ElectriciansForums.net] Stupid Bloody Lightbulbs![ElectriciansForums.net] Stupid Bloody Lightbulbs![ElectriciansForums.net] Stupid Bloody Lightbulbs!
Any help would be greatly appreciated!
Cheers
The silver ring that holds the opaque glass in place will usually have two to three little prongs holding it in place. Gently try prizing it up from different points on the silver ring part. Or it may twist a little as someone suggested.
It is possible that they may be completely factory sealed units that do not allow the end user to open, I can't quite see the detail required to see a definite method of opening them, but I would suggest a search on the manufacturer and model number (if they are on the light fitting) should give you the manufacturers installation and maintenance instructions.
Reply to Stupid Bloody Lightbulbs! in the UK Electrical Forum area at ElectriciansForums.net
I think you mentioned changes bulbs in one message then change lights. There is a difference. Are you changing a bulb or a light fixture? If...
2 3 4 5 6 7
5K
Cbelectrics
C
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
