Stupid positioning of consumer units... | Page 3 | on ElectriciansForums
Discuss Stupid positioning of consumer units... in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Called by a customer yesterday as the cover on the consumer unit has come off and they were panicking. Agreed to call in this morning.
Its a new build house, the consumer unit is located immediately adjacent to the side door. When it opens the door handle/ lock bangs into the cover.
Over time it has become dented and eventually the left screw has come loose and the cover popped off. BG boards are prone to having a tight or misaligned cover at the best of times.
Surely the original electricians must have thought about where they were putting it?
It seems these days more and more of them are put in daft places in the middle of a hall way wall or by a door sticking out rather than out of sight in a cupboard.
Whats the most stupid or strange place you have come across a consumer unit new or old?
Have come across one immediately above a bath tub and shower before, suffice to say it was an immediate C1.
This one. Recent kitchen too, one-piece corner cabinet, 500mm door.
[ElectriciansForums.net] Stupid positioning of consumer units...
Worst I saw was mounted, along with the head and meter, in an alcove to the side of a chimney breast. Then a stud wall was put over the chimney breast. Then a kitchen was built over the wall. Access was through a base cupboard. FFS !
came acroos a job recently to add a coule of kitche sockets.done it by fitting RCD FCU. DB was a wylex 3036 mounted below kitchen sink.that was original build from 1970's.
Went to do an EICR once in a cottage with exposed beams, DB was over front door but unfortunately plumber had been in and fitted central heating pipes in front of DB and was not able to remove cover. So ended up having to smash cover off and lowering and fitting new DB.
Here's my mate gaining access :tearsofjoy:
I had one half inside and half outside a kitchen cupboard, as in sticks through the worktop.
Had to remove the worktop to reset the MCB’s
Coded it on an ECR but tenet refused to let us move it.
Reply to Stupid positioning of consumer units... in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
