Sub Main Armouring Earthing Question Combined CPC and Main Bond | on ElectriciansForums
Discuss Sub Main Armouring Earthing Question Combined CPC and Main Bond in the UK Electrical Forum area at ElectriciansForums.net
John-
Uk
Hi
I have reviewed a few posts around this subject, but my question is not covered. I know that the Submain Earth has to be sized on the DNO incomer, not on the submain to the external building itself. My question is if I need two main bonds in the submain building, for example one for ground fed metal pipe for water and ground fed metal pipe work for gas, does that mean the equivalent earth sizing of the armoured / extra conductor in the armour, must also be sized to take account of 2 x 10mm or just one 10mm (example assumes TNCS with 25mm Line. Or is there something in the regs that assumes one fault to earth only and not multiple?
Thank you.
John
as long as the SWA is 3 core. the cpc is adequate for bonding, the steel armour is superflous. but must tbe earthed, as you know.
on one specific armouring is used (TPN 4 core cable only) for CPC (installed a long while ago). There is another sub-main in this building which does use a core for CPC. Same size too. Was thinking of joining both armouring and the SP CPC and creating a sub MET in the building and then running the main earth from this Sub MET so shared across two sub-mains for both supplies. I should state that the Single Phase board is supplied via a manual change over switch to be fed via generator in the event the site mains fail.
It won't be a Sub MET (MAIN Earth Terminal), it would be an EMT (Earth Marshalling Terminal). Common practice on a lot of sites to use this method.
Thank you. By the way what is the best way of knowing the exact size of the DNOs supply conductors? Would they know if i called or have i got take it apart and measure?
Thanks.
Reply to Sub Main Armouring Earthing Question Combined CPC and Main Bond in the UK Electrical Forum area at ElectriciansForums.net
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
