Hi all,
Trying to get my head around an external install to a garden shed.
I've run a 4mm H07 cable for the distribution circuit radial from the house. The 4mm is appropriate for VD over the distance. The cable is protected by RCD at the main consumer unit and a 20A MCB and travels up the garden clipped to a concrete wall. Then into the shed.
If I install a consumer unit in the shed, do I need to run a seperate earth cable as well? My head is saying no, its no different to running a radial, yet I keep thinking, consumer unit, seperate earth?
The installation is TN-C-S PME
The CU in the shed will be populated as:
100A Main Switch
16A MCB, 2.5mm T&E for socket radial
6A MCB, 1.5mm lighting circuit
Can someone explain why I'm getting confused?
Mikey
100A Main Switch
Mikey
