Discuss sub main in the Australia area at ElectriciansForums.net
sub will be supplying
electric hob/oven 12kw
2 x ring mains
2 x lighting
1 x smoke alarm
3 x outside lights
1 x boiler
as the supply is single phase and being split for two cu i was going to instal a 63amp fuse for protection for sub cable and to stop overloading to main cut out fuse. does this sound ok?
16mm SWA is well happy with a 63A fuse.
Reply to sub main in the Australia area at ElectriciansForums.net
