Submain Query | on ElectriciansForums
Discuss Submain Query in the UK Electrical Forum area at ElectriciansForums.net
E
Electric Eales
Hi All,
Been asker to run a submain 100m metres from origin to a shed. This shed will have a 7.5kw shower, 6kw oven, 2 x 3kw water heaters as well as general power and lighting(not much about 12 lights & 12 twin sockets)
Not sure if running 3 phase supply would make more sense? Financially and size of cable for glanding etc. Any thoughts?
Hi All,
I would say it would be essential to run three phase in order to balance them evenly. All that lot on a single phase would be poor loading/overloading of a phase if single phase was used
First poster strikes again lol
Hi All,
Ok thanks, do you think a 40amp TP&N supply would be sufficient?
I should say work it out yourself, which you should do.
However its pretty easy
Shower approx 30A put on L1
6Kw Oven on L2
2x 3Kw water heaters on L3
Then split your sockets and lights over L2 and L3
No load exceeds 30A ish so witha 40A you have allowed 25%ish extra capacity I would say thats a pretty good sizing for what you have intended.
Now you will just have to work out cable size to accomodate for Volt drop etc. and ensure you take suitable sized earthing/bonding conductors if necessary.
Just to add though, you may have to measure current on each phase when in 'normal service' and jiggle the circuits around in the db, however with the fixed loads you have I would say above arrangement would probably be the best you can do.
Reply to Submain Query in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
