submains | on ElectriciansForums
Discuss submains in the Australia area at ElectriciansForums.net
sparkie-leeds
Can i run a submain from the garage into the house study room in 25mmpvc/pvc tails, apporx. 15mtr run, the garage is attached to the house and all the ceilings have been taken down? or any suggestions on a cheaper way? would i be able to install the tails in the wall down to the new mains board...
I'm not sure on running the tails in the wall - someone with more experience would be able to answer that one. But it would need a seperate isolator because the tails are longer than 3 metres long
Seems like a big job for something that might happen once in a blue moon. How often is there a problem in a house if it is all going to be rewired?
I'm randomly guessing that it's going to be re-wired due to ceilings down and moving c/u into a different part of the house
Beat you to it micky
[ElectriciansForums.net] submains
Over the 3 meters from suppliers equipment,best fit a switchfuse
Reply to submains in the Australia area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
And if it's a garage then use metal clad accessories.
