View the thread, titled "submains" which is posted in Australia on Electricians Forums.
sparkie-leeds
Can i run a submain from the garage into the house study room in 25mmpvc/pvc tails, apporx. 15mtr run, the garage is attached to the house and all the ceilings have been taken down? or any suggestions on a cheaper way? would i be able to install the tails in the wall down to the new mains board...
i will run it in 2 core 16mm aroured cable with switched fused isolator in the garage, will earth the armoured up at the switched fuse end, if i run it in 16mm this would take about 100amps which would be ample for the installation, your thoughts chaps?
Reply to the thread, titled "submains" which is posted in Australia on Electricians Forums.
