Subs | on ElectriciansForums
Discuss Subs in the Australia area at ElectriciansForums.net
is it because a ship has an anchor?? means of earthing as a conductor?
where a submarine could be classed as a non conducting location??
not sure how good a conductor seawater is, but apparently freshwater isn't a very good conductor & it is only the impurities in the water that conduct???
only thing i could thing of without checking google :p0
Why Poland? are polish subs not compatible with normal rules of physics?
btw extreme care is needed when chopping out socket boxes ; which is a diversion from the question -:
i
:p0
I am guessing that sea water is not a good conductor
I believe it is used as the dialectric for the "help me" battery when the pilots ditch their planes in the sea
If any of you do have to make chases in a submarine,dont frorget to wear ear muffs :)
Reply to Subs in the Australia area at ElectriciansForums.net
Can't imagine why it might be a problem as spring tension will remain constant. Could be some issues with space constraints. A quick google shows...
nicebutdim
N
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
