L
LlandrilloSpark
Hi Guys
Done a small job for a local heating engineer this morning just a simple FCU to the ring to supply the combi.
Potential problem is this:
The house suffered a powersurge last year and all credit on the meters was lost, the homeowner called out an electrician who also noticed the house had no earth, he fitted an earth rod and Wylex dual RCD consumer unit, full certification, good job.
Whilst on the job i noticed the house is crammed full of GU10 lamps which frequently blow, maybe down to poor quality, of course when they blow they trip the RCD, I had to tell the plumber and the homeowner that every time this happened the they would lose their heating as it is protected by the same RCD as the lights, they were rather concerned, Unfortunatly the thermostat is wireless and everytime the supply is lost the plumber will have to be called out to reprogramme it, not ideal.
The homeowner has asked me for a possible solution.
I intend to install a new supply circuit for the boiler that is NOT RCD protected, is this wise?
Also there is an issue with how i connect this, I cant put an unprotected circuit in this CCU unless i put the circuit neutral in the main switch and also the line which im not keen on
first thoughts were to move all the lights to the other RCD, this will solve the problem but if the RCD trips for another reason then obviously it , then i noticed bizzarly some of the kitchen lights are on the ring!
Then im thinking change one RCD to a Main Switch and the four circuits to RCBO's and then insert a standard MCB for the new circuit.
Any other suggestions
cheers
cheers
