Suggestions please | on ElectriciansForums
Discuss Suggestions please in the Australia area at ElectriciansForums.net
O
Octopus
Just been to see a job where I would need to replace a FCU with a RCD FCU as its to supply a fan heater (1kw) in the bathroom. Easy I hear you say but...
the existing FCU is in the adjacent kitchen and its the first spur off the ring and there are 2 more sockets linked off the FCU (not through the FCU) making 3 points off the ring as spurs of spurs.
Thought about using the existing FCU to "control" the new RCD FCU, and the 2 sockets, but the existing sockets are for the fridge (0.5kw) and the washing machine (3kw) making the possible load about 4.5 - 5 kw (worse case) so the FCU would almost certainly blow fuses on a regular basis.
Extending the ring to the FCU isn't really on as it would mean disturbing their new tiling in the kitchen!
Any suggestions please!
without visualizing the job, may i suggest leaving the existing ( bad practice ) FCU as is and come from somewhere else with your RCD FCU.
How much area does the ring cover - could you split the ring into 2 radials at the point where the extra sockets spur off?
Even that would be borderline.
IMO it should really be rectified properly, even if it means re-tiling.
if you are careful you may be able to remove the tiles without breaking them. soak in water over night and scrape off adhesive next day. refit when wiring in.
Reply to Suggestions please in the Australia area at ElectriciansForums.net
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
