Suitability of circuit accessories.
That's about protective devices, it certainly doesn't refer to selection of under rated accessories?
I think you need to take a break and cool off.
Just relax and re-read what you have said and the responses, then think about it, it appears like you are reacting rather than analysing.
Since the advent of plastic, self extinguishing, isolators / accessories, Yes, many times.
Moreso on circuits with a protective device that matches the Isolator rating, or even less, than those where it didn't.
You've reported your concerns, they've been dismissed, that's it as far as you're concerned.
Having re-read your post I understand what you're saying about reporting my concerns & I apologize unequivocally for my somewhat surly reaction. :)
That's funny, I just haven't seen anyone post anything that makes sense, you were doing ok though Julie until you quoted a completely irrelevant regulation.
Ok, let's try this
You have a cable capable of 20A on a 10A load
If I fit a 40A MCB, is the cable undersized, or is the MCB over sized?
If you say it's the MCB that's too large then 432.3 would be appropiate
The standards always work from one direction only.
They don't put the point in both directions
There isn't "1.2.3.4 :equipment must be suitable for the Voltage of the system" followed by the opposite viewpoint "1.2.3.5 : A Voltage unsuitable for the equipment must not be used"
It is necessary only to confirm one point of view.
Ok, let's try this
You've lost me...
You've lost me...
Your thought, that the isolator is undersized @ 20A, is based on the fact that the protection is 32A
This is EXACTLY the same as saying the protection @32A is oversized as the isolator is only 20A
The regs only need to cover one point of view as the other is automatically covered!
IEC standard 60947-3 (same BSEN number) which covers switch disconnectors or isolators will tell you that they must be designed to withstand fault currents flowing through them until the protective device operates.
From what you have discribed there is no problem with the way the circuit has been installed.
Not really, the circuit supplies 2 split units each drawing around 12A so it has been designed as a 32A cct for that reason. I see what you're getting at but this has been designed as a 32A cct & is wired in 4mm singles. The isolators that have been fitted are there because of the availability of the correct parts in the location I'm in.
OK, but your view is that the isolators are undersized @20A, based on the protection device of 32A. This is exactly the same as the protection device is oversized @ 32A compared to the 20A isolators as far as the regs are concerned; 432.3 details why this situation is permissible.
As long as it's a fixed load and it has fault protection, it is compliant
If these same isolators supplied multiple outlets, then it's not a fixed load and your point would be valid as someone could just plug in more loads resulting in overloaded isolators.
The what about 20AX switches on a ring final circuit with a 32 amp protective device? Millions of homes in the UK have this set up with no adverse effects.
Leezo,
Strima,
