Suitable RCCB replacent | Page 2 | on ElectriciansForums
Discuss Suitable RCCB replacent in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
I need to replace this old RCCB with a suitable replacement.
Currently the one installed is not tripping on test and from the test point. Changing the entire consumer unit is not financially viable for the home owner at present so I would like to change this to at least reinstate RCD protection.
Any help would be appreciated
might be on a PME system, the N-E fault could case current to flow through E to MET and as this is strapped to N at the cut-out, backfeed through N to the RCD inhibit it from tripping. only a guess mind. as for above post. if i recall, it was a dual RCD board in one case and both RCD faied to trip.
Reply to Suitable RCCB replacent in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Our house in a row was built in 1971 and we have metric cables with cpcs for the lighting, top of the row imperial and no cpcs.
