G
graham123
if you have plastic pipes feeding a mixer shower unit, does the micer shower unit need supp bonding?
So because i get a reading above 1667 ohms, the mixer tap does require a supplemetarty bond to the electrical circuits in the room
Have sorted it now, so, insulation resistance test between the cpc at light fitting and the mixer tap was >999 so its just a metal part and does not require a supplementary bond. Now in an EICR their is no 30ma RCD protection in the bathroom. So am i right in saying C3 as their is no extraneous conductive parts?
Confused? So your doing a EICR but don't know how to test for supplementary bonding? I would question your competency level! Sorry
bond the plastic case of the shower to the plastic pipes. can't do any harm then.
Supp Bonding
Thread Tags
Tags Tags
bonding
graham123,
Geordie Spark,
