Hi guys,
my brother is building a bar in his garden that is timber framed and wants some power to it.
The main board in the house has a pme earth and there a no spare ways in the board. From this board there is a 4mm t+e on a 32amp breaker off the rcd side supplying a board in a little out building about 3 metres away from the house. This out building has a 63amp main switch and a ring circuit but the circuit draws no load as the sockets aren’t used apart from a little pond pump which I’ve checked the rating off and draws about 1amp at most.
he wants power to the bar he’s building which I’m thinking off installing a garage consumer unit in, and running a 6mm swa cable from the outbuilding board(which is about 45 metres away) with a 40amp 63ma rcd main switch at the new board . The bar board will supply a few sockets, heater and lights and maybe a 13amp hot tub in future. I’ve worked out that maxium demand with everything potentially plugged will be about 27amps but it’s very unlikely the load will get this high.
My question is, would a 6mm swa on a 32amp breaker in the outbuilding board be okay to power the bar board even though the outbuilding board is only fed off a 4mm twin cable from the main board on a 32 amp breaker?
thanks
thanks
