Supply cable and switch gear | Page 5 | on ElectriciansForums
Discuss Supply cable and switch gear in the UK Electrical Forum area at ElectriciansForums.net
Telgee
Kent
hi there all ...a friend is having works done to there lord of the Manor House and are converting a barn to a 2 bed house also having a car port with 3 electric fast charge car chargers
Car port is 70 metres away
Barn is 100 metres away
Supply is being moved in the house to new location out of the cellar and they are already being charged ÂŁ9000 for that which is 3 phase so they wanna save some cash by running there own supply cables for carport and barn conversion what cable should they run ?? Also what other things need to be purchased and put in place until they hire a sparky to connect ??
Any advice gratefully accepted
Reply to Supply cable and switch gear in the UK Electrical Forum area at ElectriciansForums.net
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
