supply cable sizing | Page 2 | on ElectriciansForums
Discuss supply cable sizing in the UK Electrical Forum area at ElectriciansForums.net
ronky
Hi ,I have a wood cabin outside 70mtrs from house incoming supply, I was thinking of using a 35mm 2core pvc/swa, as I think a TT system would be appropriate for the cabin, owing to the distance away from house load would be allowing for diversity would be 51amps, seems a lot but it will be a live in dwelling with all requirements for cooking heating etc,am i correct with supply size Thanks ron
Whilst cable size has been worked out to 25 or 35 due thought needs to be given to the terminal sizes and termination practicalities.
You can buy pin lugs to reduce 35mm to 25mm, since the 35mm size is only required for VD an not load, there is no issue in this solution.
Don't see why at that size you can't use the house's earthing system. Utilizing the armor of the SWA as a CPC. Unless you have extraneous services entering the outbuilding.
A switch fuse would be more ideal to provide protection for this cable, purely to meet discrimination with MCB's that I presume are going to be installed in the outbuilding.
Reply to supply cable sizing in the UK Electrical Forum area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
