Supply down to garden shed | on ElectriciansForums
Discuss Supply down to garden shed in the UK Electrical Forum area at ElectriciansForums.net
london
Small garden shed needs supply for x2 socket and a lights.
Client does not want anything fancy like a fuse board due to light usage of garden lawn mowers
Socket will only be used for lawn mowers.
The supply will be taken from the existing ground floor ring, the SWA from the house to the shed will be clipped to the garden solid wall, length of run 10 meters.
My question is would I need to put the fused spur at our point the circuit leaves the ring (rear house) or could I put the fused spur in the shed?
I will then use a 6a fused spur for the lights respectively
OK, what does Appendix 15 (page 505 of BBB) tell you to do?
Not getting as you mate...
[ElectriciansForums.net] Supply down to garden shed
There you go mate.
Reply to Supply down to garden shed in the UK Electrical Forum area at ElectriciansForums.net
Thank you for another very helpful response. Just to assure you we are saying the same thing, I was referring to the 2.5 on 20A radial which I now...
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
