J
JRave
Hi all,
I'm having some trouble designing an installation for an outbuilding.
It's about 110m from the nearest CU in the house, which is fed via 16mm T+E by the main db, a good 15m away.
The building will have something like a 9.5kw instantaneous water heater in it, as well as about 3kw worth of electric heating plus lighting and one power ring.
I've made some calculations using a design current of 80A, as I can imagine the shower pulling the water heater, while the heating is on full blast and the kettle is on.
So I'm getting back that I should use 70mm 2-core SWA, which is massive. I've got the problem of getting such a big cable dressed tidily around the house, and then terminating it with additional termination boxes at either end.
This is the first time I've had to come up with a supply like this and I'm worried I'm going overboard.
I've looked seriously at diversity, but with the scenario I described before, I don't think it will apply much here.
The quote I've had for the cable is ÂŁ9.82p/m. The materials for this supply alone will hit the ÂŁ1500 mark so I'm worried that's a bit steep also.
Another thing is that it's a tree house! So it's all wood. The walls will be clad either side with insulation between an I'm not finding anything to suggest I should use any specially rated cable. It's only a 4.5/6 meter room but I was thinking of going low smoke.
Any help/comments gratefully welcomed.
Thanks,
John
Thanks,
John
