Supply Protective Device type | on ElectriciansForums
Discuss Supply Protective Device type in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all,
I am stuck with this one:
How can you determine what BS type is the supplier main protective device? The one before the CU.
I was doing a PIR in an old house and I am stuck with this one.
Thank you!
Dont bust a gut over it....if i'ts the DNO fuse and i'ts sealed it will be a BS fuse so does it really matter?....personally if there is no Bs type number visible I just write 'not ascertained' in the relevant section.
Reply to Supply Protective Device type in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
You won't fall fowl of anything you are installing a 32A socket it is up to the user how they employ it.
