Discuss supply System in the Australia area at ElectriciansForums.net
Aav gorra numba fo NEDL if yarra geordie wor kid aal dig it oot fo ye if ye wannus tee
Giz a minute bonny lad aal have tu gerrit off me emailI am a geordie wor kid, lol. send is the number please
It could be a TNC-S system that needed to be PME'd as the lead sheaths were breaking down on the system. But that to me doesn't look like a DNO install, i doubt very much if they would use screw clamps and a bit of cut off earth clamp tape to bridge the 2 cables.
Check with the neighbours installs, see what earthing system they have. If yours is PME'd then they will all be!!!
I presume that the sticker (when it was there) proves that its a legitimate conversion and as you can see its been been torn off to access the seal to the main switch to do some sort of work with the main switch but its hard to tell how long ago it was.
Trev1: Would you advise to get a isolator fitted between meter and CU and at the same time Q NEDL about the conversion?
Yes I would mate... Heaven forbid... E54 go wash your mouth out with soap for even thinking of such a thing heheI presume that the sticker (when it was there) proves that its a legitimate conversion and as you can see its been been torn off to access the seal to the main switch to do some sort of work with the main switch but its hard to tell how long ago it was.
Reply to supply System in the Australia area at ElectriciansForums.net
