Supply to outbuilding | Page 2 | on ElectriciansForums
Discuss Supply to outbuilding in the Electrical Engineering Chat area at ElectriciansForums.net
No point running a 6mm SWA from the FCU.
[automerge]1569958091[/automerge]
Bet me to it Tel.
i wouldn't worry about that, esp if LED lighting is used. bear in mind that you probably have > 230V anyway.
Is this a job for a customer, or at your own property?
Are you doing the testing and filling in the installation certs yourself?
Hopefully, I've just completed the part p course, so going to give a body a call, (prob niceic, unless you can advise otherwise), so should be able to do it myself. Concern would be if I have an assessor.
Ah right. I'm with you. So you're using this job as your assessment job to join a scheme.
There will always be an assessor on your first job @Dan Carroll, I’d advise an easier job as your first assessment mate.....once you are a member the technical department will give you all advice you need, have only skimmed through the thread but why are you using 22 as your lb?
That's an added bonus, but primarily its for the work experience.
[automerge]1569959828[/automerge]
I'm going to phone them tomorrow. Can I get away with wiring a plug
Not sure you could write a large enough cheque for that mate ha ha ha but seriously being realistic a small Cu change is gonna be easier from a design and calcs perspective than extending to an out building...
True.
I have, in my time ignored, cut corners, and done my own thing, mechanically on helicopters, BUT it was always safe, I knew the procedures and the risks, and it was only on the item's that where not essential or important. Where you could apply common sense to get the correct result.
I feel (and again, stop me if I'm out of order) that volt drop is like that.
I appreciate that there is a time and place where it is vitally important, but to run a few LEDs and a phone charger, doesn't seem to be one of them
True.
I’m sure your corner cutting came after many years in the trade with lots of experience, I dare say you’d never even consider it at the beginning of your time? I think your doing the right thing here and trying to understand and do it properly, trouble is here once you’ve touched it and signed it off you are now responsible for it, is this install already here or are you designing it now? If so follow @telectrix advice mate...
It’s also rather pointless having a cu in the outbuilding with a 16A MCB if the origin has a current limit of 13Amp.
You are supposed to provide discrimination of protective devices.
Reply to Supply to outbuilding in the Electrical Engineering Chat area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Thank you so much for that! When I went to do the Ze at the DB, I tripped the RCD in the CU in the house, I understand that's a hard question...
Yes, I was referring to simple installations such as domestic as that is what the thread is about. I also said should rather than must because I...
davesparks
