Hi, after a bit of advice, i need to install a supply to a shed at the far end of a garden. There is to be a small consumer unit in the shed, feeding a couple of sockets and a 2 lights. The existing system is PME and the existing fuseboard has an upfront 30ma rcd, (use to be TT a few years ago). So the way i was thinking of doing it was to split the tails & install a small consumer unit next to the existing one a with a main switch and a 20a breaker to feed the circuit, pvc conduit up the side of the building into an adaptable box then SWA to the fuseboard in the shed. The fuseboard in the shed will have an upfront 30ma rcd & couple of breakers.
Anyone think of a better way or does this sound o.k
Cheers
Cheers
