- Joined
- May 29, 2011
- Messages
- 7
- Reaction score
- 0
The present situation. Main Supply service head 3 phase + N 100amp located and terminates within basement of shop premises.
this service presently supplies 1 consumer unit via electric meter serving shop only, mounted in the basement.
The upper three floors presently have no electricity as they were for storage only, the landlord now as plans to convert the upper floors to residential flats.
the landlord wants all the metering and switchgear to be installed in the communal area/ entrance for the upper flats, this entrance is separate to the shop.
its 10 Metres away.
the shop owner does not want to allow access for future flat owners to the basement area, so all metering will need to be located in the communal area for the upper flats.
advice on method to get from existing service head located in the basement to new metering position for flats.
would it be necessary to install a ryefield 3 way 60 amp splitter located close to the service head then 3 100amp sub mains to new metering position.
or
would it be acceptable to install a 100amp three phase isolator at the service head position then a 3 phase+N sub main supply terminated into a 3 way 60 amp ryefied board at the new metering position.
any views on method would be appreciated, it may be that I will need advice from the Network Suppliers.
regards Doubletime.
its 10 Metres away.
or
regards Doubletime.
