Supplying garage with power | Page 2 | on ElectriciansForums
Discuss Supplying garage with power in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Whats needed is some aluminium framed greenhouse queries with paraffin heaters in them.
Q.
Do I bond the frame to the nearest wet tree?
A.
Why the fXZ! do you need to bond it?
Or similar scenarios:)
you need to first determine if it's ex-treeneous
the tree is.................lol
the aluminium framed greenhouse is............technically
but there's nowt else there except the odd passing Double insulated lawn mower lol
So basically their clumps of clart in my garden :)
Reply to Supplying garage with power in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You cant just "avoid" the use of RCD's for nuisance tripping... it will depend on how the cable is routed. (ie buried less than 50mm) What has...
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
