surface wiring inside container? | Page 2 | on ElectriciansForums
Discuss surface wiring inside container? in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Evening all,
I am pricing a job to run conduit for all accessories within a 20 foot container. the container is not getting internal lining.
As far as I know, containers are single skin. what fixings have you guy used in the past.
thanks
magnetic saddles ;)
Actually, someone at Elex last week was showing magnetic cable management accessories. I wasn't expecting to use them myself, so I didn't take any details, but even the small ones couldn't be pulled off by hand.
This link is to something similar, but there were much bigger and stronger ones available:
CEDIA Find: Clever Magnetic Cable Management Clips from Garvin - Cedia News Article from CE Pro
Edit: I think it was this lot at Sandown:
http://www.magdaddy.co.uk/
The other issue is these magnets are extremely strong to forces in one plain but can be moved across the surface with significantly less force so not really suitable as a full fixing solution, their are plenty of bonding agents that will adhere to any surface will good environmental resiliance so that would be my choice of fixing.
Reply to surface wiring inside container? in the UK Electrical Forum area at ElectriciansForums.net
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
