Surge protection | on ElectriciansForums
Discuss Surge protection in the UK Electrical Forum area at ElectriciansForums.net
smiffy911
Hello,
I need to install surge protection to a new installation. The consumer unit will be a 12 way 17th edition board. I have never had any experience with surge protectors so was hoping with all your knowledge you can enlighten me...............:bulb2:Cheers
Hi, They require surge protection as the house has been hit by lightning previously. A lighning protection system will be installed by an specialised lightning contractor. Thanks
As Richy says I'd speak to your wholesaler about a Class I&II surge arrestor kit. They're very simple to install technically speaking but the logistics of finding room for surge arrestors might require a separate enclosure to be installed at the CU.
Reply to Surge protection in the UK Electrical Forum area at ElectriciansForums.net
You can get surge-protected 13A plugs such as this...
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
