SWA armouring as Earth | on ElectriciansForums
Discuss SWA armouring as Earth in the UK Electrical Forum area at ElectriciansForums.net
The middle of nowhere
At what size of SWA cable are you required to run an external earth ? I'm inspecting a distribution system and its a complete mess. No main earths anywhere but they have utilized the armour and are using at is their earth. I can't find anything in the regs book, is there possibly something in the guidance notes I can refer to ?
Hi Paul - if you've got GN8 its Appendix B. There's a few tables, this is just the first one. Hope that helps :)
[ElectriciansForums.net] SWA armouring as Earth
SWA CPC.pdf
  • SWA CPC.pdf
There is no limit on size where a separate conductor is required, it depends on the individual conditions of the installation.
When assessing an existing installation the table 54.7 can be used as a first reference, but if this shows that the armour is inadequate you must then use the adiabatic equation as that may show that it is adequate.
Table 54.7 often gives a larger conductor size than is actually required.
You also need to consider whether the cpc also needs to perform the function of a bonding conductor, this usually changes things considerably.
Reply to SWA armouring as Earth in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
