SWA as CPC | on ElectriciansForums
Discuss SWA as CPC in the Australia area at ElectriciansForums.net
I
ICE
For those of you interested in wether a SWA can be used as a CPC read the attached PDF written by a colleague of mine a while ago.
Your comments will be welcome.
:cool:
  • SWA%20and%20Earthingby%20John%20Peckham%20version%20Jul06.pdf
Reply to SWA as CPC in the Australia area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
