M
mamba
Work on a job where the pulled in 4 core 50mm swa [TP + n] with a seperate 35mm main earth. Does the swa still need to be bonded ie 10mm brass screw bolting down banjo together with a lugged 10mm cpc from banjo to MET. I say yes as I feel the armouring within the swa still needs to be earthed however supervisor claims not required any answers or references to clear this up.
